438
This discussion topic is read only This discussion topic has been answered Discussion topic: Download Failed technical fault
This message was authored by: brad278
Hi all,
I've just got in tonight and tried to download on demand. Keeps failing on sky max and docs but I've tried sky Atlantic and that's working.
I unplugged for 30 mins, but it's made no difference. I'm usually great at solving issues but this one has me stumped
Re: Download House on Peacock
@Joanie57 @lexielew
All is explained via the links that have been posted multiple times here:
https://www.sky.com/help/servicestatus/tv
We are aware that users may receive a technical error message when downloading some content on their Sky Q/HD boxes. We are investigating this issue and apologise for any inconvenience caused.
Locked
This message was authored by: jowhitby
Constant failed on demand
Hi all.
I am trying to download from the on demand boxset session. Was working fine last night, but now keep getting "failed" banner across the top, when I try. I have turned box set top box and router off to try and see if that worked. It's fine when recording normal live tv only seems to be the on demand that it fails on.
Re: Constant failed on demand
@jowhitby wrote:
Hi all.
Hi @jowhitby
There does appear to be quite a few issues with On Demand and 4G broadband.
If you are not on this
@oldfella @Just tried to do what you said, no joy, it's just so frustrating. Thanks for your help though 😊
This message was authored by: Lloyd196
Technical Fault Download
I can't download anything as it says there's a technical fault, I've switched my box off 3 times and re started the wifi and still won't work. Can anyone help?
This message was authored by: Focaltrip
Re: Sky Q Downloads stuck at 101%
I also have this issue just started trying to download episode of sat night live from sky comedy.  The download starts then flashes up no subscription then starts and stops @ 101%.
@Focaltrip try deleting the programme then going into deleted programmes and deleting it from there finally try downloading it again
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Skittlessteve
Downloads failing
I can't download any programmes from my homepage or my on demand page. A message reads "download failed. Technical error"
Everything else with sky Q and internet is working fine.
This message was authored by: JayneK65
Download fail message on sky history programme
Hi. I'm trying to download 'Alone' S9 on sky history that says is 'available until 26th November ' but every episode I try says 'download failed' Sooooo frustrating as watched E1 & 2 and now can't watch the rest. Any ideas?
This message was authored by: Grundig1
Download failed
Hi there when trying to download a programme on sky plus HD box,I'm getting a download failed message. Anyone know how to fix this?
This message was authored by: Juicy1970
Re: Technical Fault Download
Mine won't download either ! 😕
This message was authored by: BettyWilma
Re: Download failed
While trying to download episode 3 of White Lotus on Sky Atlantic I am confronted by message download failed. Have tried other programs and received the same message.
I can access You Tube, Netflix and BBC i player.
it seems to be an issue with Sky programs.
please help
This message was authored by: Keyra
Re: Download failed
I am also experiencing so looking for advice as well.
Re: Download fail message on sky history programme
Have you tried the SD version if it is the HD one that keeps failing ?
Im having the same problem. Just today. Seems to be any sky program,  as the bbc and ch4 programs are downloading fine.
Locked
