Discussion topic: Remote network problem
Message posted on 05 Jul 2020 05:17 PM
Hi all as above-wont download anything
Message posted on 05 Jul 2020 05:30 PM
Re: Remote network problem
@Andysate , do you mean you have an internet problem or an issue with Q mini & tv?
Message posted on 05 Jul 2020 07:05 PM
Sky Q-wont download a missed prog get so far then get the above message-turned off and on -no good
Message posted on 08 Jul 2020 10:38 AM
I am getting this too, when watching a series some episodes I cannot watch. Either says "no subscription " or "remote network problem ". Just on odd episodes, so annoying. Have rebooted Q box but still the same!!!
Message posted on 15 Jul 2020 09:54 AM
Hi,
I've been seeing the same for weeks now as well. Pretty sure it's not a SkyQ networking issue, as I get this while watching TV on one of the Minis, showing that the connection between the Mini and the SkyQ is working fine. Also as sure as I can be that it's not a broadband issue, as other devices work on my broadband without any problems when this issue occurs.
Had the new software update last night, so will see if this has changed anything.
Andy
Message posted on 15 Jul 2020 10:04 AM
Remote network problem usually indicates the problem is not with your local network, hence remote. It could be your broadband connection is experiencing issues or there are server issues at the data centre Sky is using to make the content available.
Message posted on 16 Jul 2020 09:18 AM
@Andrew+Hawkins wrote:Hi,
Nope, had a load more of these last night while trying to download stuff using the horribly convoluted method I have to use with the new interface. Even more frustrating now as I have to manually go looking for each episode, rather than just being able to select it from 'More showings' or whatever it was.
Andy
Message posted on 27 Jul 2020 09:50 PM
Yes I have been having the same problem. Never seen it before the upgrade (the terrible new interface). So I would suspect it not peoples networks it's a bug with the new release. Just be persistent and it will download eventually, that's what I found. And it is random.
Message posted on 28 Jul 2020 09:23 AM
@Zippy101 wrote:Yes I have been having the same problem. Never seen it before the upgrade (the terrible new interface). So I would suspect it not peoples networks it's a bug with the new release. Just be persistent and it will download eventually, that's what I found. And it is random.
It most definitely is not a bug solely in the new release. I've been seeing this for weeks if not months, certainly long before the horrible new interface dropped.
Seems to have died down a little for me, so it's possible it is some kind of load issue at Sky's end, which comes and goes depending on how busy things are.
Andy
Message posted on 28 Jul 2020 09:32 AM
I just posted in the other topic about this but i'm also seeing a lot of failed downloads with "Remote Network Problem". It appears to be a problem with the advert server adm.sky.com as anything with no adverts (mostly BBC ) or ads not provided by that server (ITV) always work. Downloads from other channels frequently fail, it is often when they get to 99% and the whole programme has to be downloaded again.
Message posted on 28 Jul 2020 09:33 AM
Good to know its not a bug but for me seems coincidental with the new software release although i have seen the 'no subscription' error before on occasion but just not this remote network issue before. One thing I did try was to change the download preferences on the main sky box from UHD to HD to see if that helps. Thus far i've not had a reoccurance of the problem. Will monitor to see how things go over the next few weeks ............
Message posted on 29 Jul 2020 09:30 AM
I never had this issue up until June 2020 when I replaced my Sky Q 2TB nox with a new one that is compatible with HDR. From the start, this message kept appearing. I followed all the instructions given to me by Sky Q Tech Team. Alas, the problem still there! Eventually, I had an engineer visit two weeks ago. Box replaced. But, engineer explained, as I have everything wired in the house these may be the following two factors for this problem:
1. Sky Q boxes are designed to be wireless, so hooking them, (Sky Q Mini box too), to a wired network adds another layer of IP address sorting within the box, (to which I'm like...ehm, a network is a metwork. Why are you making network products that will not work well with a wired Ethernet connection?!)
2. TP-Link Ethernet switch, which my box is wired to, are renowned to create issues with Sky Q boxes. Aparraently this brand is at the top of their fault finding list. (Again sceptical....really? Something tells me if there was another brand of Ethernet switch, I would have been told the same thing).
Engineer suggested to leave the whole set up wiree in, and if the problem persists then to switch to wireless. As the WiFi router is in the same room, I won't see much issues with speed.
Having read a lot of posts on this issue, something tells me that it must be a software problem.
I realise that this is not a solution; nevertheless, I thought it would be good to share my experience.
The Sky engineern was umber useful, considerate, (including COVID safety gear), !ethodical. Regardless, when I saw his reaction to a fully wired set up, and advising to drop that and switch back to wireless, ( also Sky Q Mini is designed to connect best via a WiFi mesh connection between main box and mini) adding wired Ethernet goes against the design of the product.
As I said skeptical, yet pleased with the serbive from engineer.
What does anyone else think on the above?
I was thinking of waiting for the new OS update to come through before I forego nyhe wired connections, just in case.
Message posted on 29 Jul 2020 10:02 AM
I would be sceptical about this. I've had my boxes hard wired for at least 3 years now with no issues. In fact in the early days of sky q this was the best option as the wireless provide by the boxes was flaky. The problem is the Sky engineers are not networking experts so it's always a challenge. I've had 3 different routers on my network with no issues. For sure there is another underlying issue either with sky or their software.
Message posted on 29 Jul 2020 10:59 AM
Seems at odds with my Tech team expert who suggested wiring a couple of the miniboxes (which a sky engineer came out to do as tech team don't do drills, yet.....), get some switches and take the strain off the Sky Q main box and wifi.
Stopped sending 2.4Ghz off everything except the Sky Hub and its like i've got a new system...
Mind you , I had no issues at all until the V1 2TB box was replaced by a V3 one.....
Message posted on 29 Jul 2020 11:13 AM
Agreed. Same here all fine wired in until swap of box / firmware update.
