Discussion topic: Sky tv keeps going off
This message was authored by GKo This message was authored by: GKo
Hello,
My Sky TV has been going off for days now.
I would get only about one hour of tv before it goes off and starts saying - "there is a problem with your satellite".
I am also unable to record any tv as well, its a nightmare.
This message was authored by Mark39 This message was authored by: Mark39
Re: Sky tv keeps going off
Check your signal strengths: Services > Settings > Signal
The white part of all four bars should be at least half way across.
This message was authored by Annie+UK This message was authored by: Annie+UK
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
This message was authored by Padam_Padam This message was authored by: Padam_Padam
@GKo wrote:
Hello,
Sky don't offer support for Sky+ any more as the system is now obsolete. You could enquire about an upgrade to Sky Q, whereupon an engineer would visit you and install a new LNB on your satellite dish and check all cabling. This would require a new contract to be agreed upon.
If you'd rather stick with Sky+ then you'll need to contact an independent local satellite installer to come and check your dish & cabling.
GKo
Sorry, my box is Sky Q not Sky +.
Does that make a difference?
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Sky TV keeps going off
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
...but will likely require an engineer to check your dish/LNB
I am just another Sky customer and my views are my own
Yes. Sky Q is supported by Sky. Follow the troubleshooting here and if you are still having issues there will be a phone number to call at the end:
@GKo  Your duplicate thread created for the same issue has been removed as you already have this one active and have received replies.
