3
Discussion topic: I use my phone for my remote control but it can't find my sky box so it won't work
This message was authored by Oxford80 This message was authored by: Oxford80
I use my phone as my remote control, but it's stopped working. It can't find my sky box as a device. I'm told network is disconnected although there's nothing wrong with my connection or internet
This message was authored by oldfella This message was authored by: oldfella Answer
Re: I use my phone for my remote control but it can't find my sky box so it won't work
Hi @Oxford80
Are you using the Sky Go App on Apple device?
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Hi @Oxford80
See following link.
Oxford80
No I'm not using the apple app
Best to keep in on the forums @Oxford80 .
It helps others.
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment.
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
