Discussion topic: My sky Q box constantly skips to a black screen. I have changed the hdmi cable and theres been no ch
This message was authored by Bec99 This message was authored by: Bec99
My sky q box constantly skips to a black screen. I have changed my hdmi cable and no change
Re: My sky Q box constantly skips to a black screen. I have changed the hdmi cable and theres been n
Hi @Bec99
