17 Jan 2024 12:30 PM
Hi
my sky remotes do not operate the tv volume any longer. I have tried to reprogram them but it doesn't seem to work. My main sky box is okay but neither of the sky q mini boxes will work. I believe there is some sort of update required?
17 Jan 2024 12:48 PM
@Sam2020 wrote:
Hi
Hi @Sam2020
When you press 1 & 3 together you must make sure that you are pointing your remote at the mini box (not the TV).
Try completly resetting your mini Bluetooth remotes.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
17 Jan 2024 12:36 PM
Posted by a Superuser, not a Sky employee. Find out moreDoubt it
So they worked with these TVs before? What are they?
@Sam2020 wrote:
Hi
Hi @Sam2020
