2
Discussion topic: I can’t get the sky remote to operate the tv volume
This message was authored by Sam2020 This message was authored by: Sam2020
Hi
my sky remotes do not operate the tv volume any longer. I have tried to reprogram them but it doesn't seem to work. My main sky box is okay but neither of the sky q mini boxes will work. I believe there is some sort of update required?
This message was authored by oldfella This message was authored by: oldfella Answer
Re: I can’t get the sky remote to operate the tv volume
@Sam2020 wrote:
Hi
Hi @Sam2020
When you press 1 & 3 together you must make sure that you are pointing your remote at the mini box (not the TV).
Try completly resetting your mini Bluetooth remotes.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
This message was authored by Chodley This message was authored by: Chodley
Doubt it
So they worked with these TVs before? What are they?
@Sam2020 wrote:
Hi
Hi @Sam2020
