156
Discussion topic: Roaming Passport Plus Not Working
This message was authored by Paul161 This message was authored by: Paul161
Re: Roaming Passport Plus Not Working
I have been having this problem for 9 months in various countries. Despite new sims on a number of occasions it is still not resolved. Sometimes never get a connection, other times get Welcome message then a few hours later the connection drops out and never returns. The request for ANP using My Sky on wifi does not work as no texts with the link received. I have gone through all of the help online but nothing works. Currently abroad and neither my phone or my wife's phone is working.
Anyone got any ideas?
This message was authored by matelot95 This message was authored by: matelot95
8th September today, been here 3 days now and still no service.
Is there any update to this?
This message was authored by NickiFree This message was authored by: NickiFree
So to make matters worse, I've now arrived home to the exact same issue, no calls or data and it says my sim is not allowed to connect to the Sky network.  I've been through all the steps yet again and still it doesn't work.  Not being contactable abroad was annoying, not being contactable at home affects my livelihood as I can't work without my data connection.  So Sky, when are you going to fix this issue or at least provide an update?
Now I'm worried
I've found a way to fix it without any help from Sky, I found a hidden menu that resolved the issue
This message was authored by PaulieG This message was authored by: PaulieG
Can you share how you risolved the issue please. Many thanks
Yes, could Nick1Free please share the solution ? Thanks
This message was authored by Sarah17 This message was authored by: Sarah17
Same. Arrived home today and no mobile data. What's going on please Sky?
@Sarah17
What device are you using ?
@caesarome Apple XR
For others having similar problems, my husband has just spoken to someone at sky who has advised that there are known connectivity issues with the provider.  Apparently there has been an outage and some phones lost connection and couldn't be automatically reconnected
*You need to call them* in order for this to be fixed. They need details of individual accounts affected so they can send a reboot to your phone.  It won't happen automatically. Apparently this takes up to 24 hours to come through.
It would have been helpful if a nice if a Sky team member could have hopped on and explained this but hey ho.
Hope this helps 🙂
This message was authored by Sjennings96 This message was authored by: Sjennings96
I'm having a similar issue I'm in Tenerife. I managed to get mine to work yesterday however it won't reset. Tried turning roaming on and off. Switching to 2g and requesting network settings but no luck
This message was authored by Vanatious This message was authored by: Vanatious
Re: No signal whilst abroad Spain
Hi, this issue still does not appear to be fixed. We landed yesterday in Spain, and my partner's mobile in my account refuses to connect. We had one brief period of connectivity last night, and received the text informing of the £2 roaming charge, and now no connection. What a shambles!!
Using the sky menu, change the roaming setting to home and it should then find the network.  I don't think it is a 'proper' fix as it still doesn't pick up the network on automatic, but you can at least make/receive calls and use data in the UK this way.
@Sarah17 wrote:
@caesarome Apple XR
@Sarah17
Try this:
Settings > Mobile Data > SIM Applications > Change to Home
