19 Mar 2024 09:54 AM
WiFi connection dropping overnight.
I recently got a ev charger fitted but it is not functioning as I would expect. I've been in touch with the supplier and they are telling me my WiFi connection is going down every night at 2:41am and comes back on around 5:48am.
How can I confirm this is true ?
Has anyone else seen anything similar?
Douglas
19 Mar 2024 09:59 AM
If its a wifi connection to a sky q box then change the eco as below
19 Mar 2024 09:57 AM
Do you have a sky q tv box that may be supplying wifi to the ev charger or is it etherneted
Posted by a Superuser, not a Sky employee. Find out more@DouglasC1 the modt likely cause if you have Sky Q is thst the charger is connecting to thecwifi hotspot on one of your Q boxes. If thst box is set to go into eco stanby mode the wifi hotspot is switched off between those hours. Solution is to change the standby mode of the box to Avtive or None.
19 Mar 2024 10:01 AM
Hi
i have a sky q box in thr living room and a sky router ih the hall. Both are close to the charger which is fitted outside.
thanks
19 Mar 2024 10:02 AM
See my link above
