Discussion topic: WiFi Max Hub router settings
This message was authored by iamnotthespy This message was authored by: iamnotthespy
so ive just got the WiFi Max hub, now when i got to 192.168.0.1 to change router name and password, i get all the information i need however if i recall i was able to change settings via this but it sells me to download the My Sky App on my phone which i have, when i go on the app there is nothing to see about changing my routers name and password?
can any one advise me where i need to go on the My Sky App to change the router settings please?
Re: WiFi Max Hub router settings
@iamnotthespy
https://www.sky.com/help/articles/change-wifi-max-hub-settings
iamnotthespy
i got nothing up besides broadband sheild, talk sheild, internet security, sky go and TV product settings :s
@iamnotthespy
I think that would suggest your login to the My Sky app has not been associated with the Max service.
This message was authored by DrSlippers This message was authored by: DrSlippers
I have the same issue. I managed to get it to show, changed my Router name and password, now it's reset itself back to default and I can't get the setting to re-appear on the My Sky App
This message was authored by Dave171 This message was authored by: Dave171
Hi, I have just upgraded my sky router to the sky Max router.
On the MySky App i do not have any settings to be able to confrigure my router.
Can anyone advise if this is still an ongoing issue with the App
There still appears to be a delay in the My Sky app populating with the necessary tabs, yes.
@TimmyBGood thanks for the reply.
so Sky are charging extra for a new router that you actually can't use fully.
No parental controls, unable to cahnge password, unable to change network name........
I just looked on the MySky app today and it seems you can now change the username and password for the router
This message was authored by Gallabrix This message was authored by: Gallabrix
I have had the same issue today, however I found if I logged out of the My Sky app and then back in again, the missing setting appeared.
