Discussion topic: Satellite issue
This message was authored by: Hayley90
Satellite issue
All my channels are working apart from 512 which is showing a blue screen with the message no satellite signal. It works in mobile devices.  Anyone have any ideas? 🤷‍♀️
Re: Satellite issue
Which Sky System do you have?
1. Sky Plus (Sky Plus Forum)
2. Sky Q (Sky Q Forum)
I am NeurodivergentMy Sky FAQs : Go Stream Glass Plus
Re: Satellite issue
GB News moved transponder to a wide European footprint rather than a narrower UK/Ireland one
this means that any slight mis-alignement of the dish can result in loss if the channel      (as well as CNN & Bloomberg which use the same Transponder)
