Discussion topic: Problems with landline
This message was authored by: LianeM
I’m receiving calls to my landline but I cannot answer them. Also no dial tone to make a call.
The phone is connected to the new router as per instructions and the voice light is illuminated green.
Re: Problems with landline
Have you tried a reboot of your router ?
If you have then try running this line test:
https://www.sky.com/help/home/broadband/my-broadband-speed/no-connection-slow-wifi/articles/broadban...
You can also run this test via the MySky app.
Let us know how you get on.
Avatar for LianeM
Yes I've rebooted a number of times as the tv regularly loses internet connection also. I've done the test and all indicators are showing as ok
Avatar for LianeM
Your only option is to then contact Sky so if you haven't got another phone to use they can also be contacted via Twitter or Facebook Messenger,
This message was authored by: octanarian
I cannott  make or recieve phne calls on my land line
@octanarian
Have you tried running this line test;
