6
This discussion topic has been answered Discussion topic: Lineline not working, wifi is ok
This message was authored by: Jackief3654
Checked all cables, plugged in new phone, no dial tone
Avatar for Jackief3654
This message was authored by: Jackief3654 Answer
Re: Lineline not working, wifi is ok
Line fault outside property! Waiting for engineer
See if you can run this line test to see if a fault is found outside of your property and if something is found you can book an engineer repair:
https://www.sky.com/help/articles/fix-phone-problems-start
Tried all that before  I posted, thanks
Does your broadband router have a voice light on it that is lit up ?
Yes. Pale green
In that case is your phone connection plugged into the back of it as it needs to be ?
