6
This discussion topic has been answered Discussion topic: Swapping a Sky+ HD Box
This message was authored by: cranfan
I know there is quite a lot already posted on this topic, but I just want to be sure before I start. The hard drive has failed on my existing HD box (installed feb 2016), I have purchased a DRX890WL to replace it (new according to the seller, although no remote).
I am proposing to install it as follows:
1) With the mains off, attach power cable, ethernet, 2 satellite leads and hdmi (TV off at mains). This box has no telephone port.
2) Insert the card.
3) Perform a software update by holding down the Back Up button on the top of the box and turning on the box at the mains, etc. (turning the TV on at mains once the update is running)
4) Once the above is complete, pair the card either by running a New Install (from Services) or by following the procedure in Sky Help (by collecting the details from Settings and entering them online or in the app) https://www.sky.com/help/articles/sky-viewing-card-help-activate-plus
My questions:
a) Can I expect the remote from my existing box to work with the new box (with no pairing)?
b) As the DRX890WL was one of the last models manufactured, is it necessary to do a software update?
c) Am I correct to insert the new card before the software update?
d) I'm assuming I can run an ethernet lead from a BT Disc, but if I can't connect with ethernet at what stage will I get prompted to enter a wifi password (presumably I won't be able to go straight to a software update)?
e) Am I correct that a New Install will pair the card, it doesn't get mentioned in the Sky Help (presumably it's intended for their staff to use)? What else will the New Install do?
f) What is the simplest way to pair the card, I have seen some mentions that you just need to connect to the internet?
This message was authored by: Mark39 Answer
Re: Swapping a Sky+ HD Box
@cranfan wrote:
My questions:
Yes.
Yes, the firmware has been updated since manufacture.
Not sure that it makes any difference, to be honest.
Software updates are carried out over the air (via your dish) so an internet connection isn't necessary.
I can't say for sure, but it I imagine it sends data about your box and the Viewing Card to Sky
New Install is the simplest. Problems have been reported about pairing a Viewing Card if you don't have an active Sky subscription.
@cranfan wrote:
My questions:
Yes.
Sky released R024.092.10.00P in November 2021 to fix an unfortunate mistake in the last mainstream release (numbered R023.091.33.00P)  The final model Sky+ HD hardware was manufactured in 2015.
https://helpforum.sky.com/t5/Archive/BST-TIME-CHANGE-PLEASE-READ/m-p/3817418
Avatar for cranfan
Thanks for the feedback.
d) So, if the update doesn't need the internet and if I use the manual method (per Sky Help) to pair the card, then am I correct that I could do the installation without any internet connection? I don't use any of the interactive services.
Yes, with the possible exception I mentioned in my first post.
Avatar for cranfan
Thanks.
I have a subscription to Signature (in contract) and a Sports channel.
Are you referring to the scenario where a box is being activated just to view free to air channels?
@cranfan wrote:
Thanks.
You'll be fine then,
Yes, problems have been reported when trying to pair a Viewing Card via a Sky adviser where there's no active subscription.
