Discussion topic: Help needed for a Sky+ HD Box
This message was authored by: Obi123
I have a Sky + HD Box, as I'm not allowed Sky Q in my Flats.
i turned my Tv and Sky on like normal, but it said I have a Hard Disk drive Problem.
i pressed the yellow button and did a Restart, it said it still wasn't fixed.
so I did a a Full Restart.
And it is still saying it's not fixed.
please help!
Re: Help needed for a Sky+ HD Box
You'll need to replace the box with a secondhand one, try eBay etc... look for DRX890 or the better DRX895 models as these are the latest versions last manufactured over 8 years ago
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
@Obi123
Note that unless you have an existing Sky Protect policy, Sky themselves no longer provides replacement Sky+ HD hardware or installer support and will just advise you to move to Sky Q, Glass or Stream.
This message was authored by: jasonIreland
did you try Services, zero, zero, one, rebuild?  i dont know, but it may help
also @Obi123 , rebuild will save your recordings, there is a last ditch effort to reformat the hard drive (obviously lose all recordings)  i dont know i can post links to the video, but search youtube for "how to format the hard disk drive in a sky+hd digibox". May also be worth a try if the box is actually on its way out and you need to get a new one anyway?
hope this helps
Avatar for Obi123
I tried that.
it's definitely gone.
but thank you.
hope this helps
The instructions for a Full System Reset (FSR) can be found in my FAQ (Q15)
sorry to hear that @Obi123 , hopefully better luck with the next one.   @Annie+UK  how do i get to your FAQ, i checked your profile, but guess im in the wrong place
sorry im blind, you have a link on the message, senior moment lol
The link is in my Forum Signature at the foot of all my posts 🙂
