310
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky catchup unusable
Locked
This message was authored by: Steve18921
Re: Sky catchup unusable
Turning that setting off my downloads kicked straight in and downloaded in seconds , I get 944mbs
This message was authored by: Geering1993
Do I change that setting on the sky box?
That was on my router settings via the app that it uses
what router you got ?
I have no idea lol. It's a Talk Talk Fibre something or other but that's all I know
Have you an app on your phone called eero ?
 Like this ?
No I don't have any app to do with my wifi
If you have , go into app
on Home Screen hit advanced security then go to network controls then toggle advanced security off
Someone in your household must have it as the router setup is done via the app
We just plugged it in to the wall and it worked. I think Sky are working on it, so I'll just wait and see what happens. Thanks a lot for your help though
This message was authored by: Davyruss
Haven't got a clue what you're talking about,
have no idea what a TTs DNS server is nor any of the other jargon!
All I need to know is have I got a problem with the Sky+HD box or not
Only you know if you have an issue or not! and with a rude attitude like that it makes it rather hard to help you 😞
Try the steps in Post #109
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
This message was authored by: Kayelaina
There is a problem downloading Sky have confirmed  it is at their end and they hope to have it sorted in 48 hours. As everything was fine with my settings until yesterday I am going to wait rather than make changes I do not understand or have to reverse.
This message was authored by: Orax
Re: Download
My downloads are failing too. I am with TalkTalk, does it matter?
Locked
Answered - Go to Answer
