Discussion topic: Sky catchup unusable
Message posted on 24 Sep 2025 11:57 AM
Re: Sky catchup unusable
@Jaskate wrote:I just checked again after changing DNS yesterday on router and still all ok, tried BBC, UK Gold, U and Paramount Plus all ok no lag or failures
After rebooting my Sky box and router, I have successfully downloaded 2 programs. But I think the "Advanced Security" network control on my Eero is affecting my results.
Further experimenting using https://www.top10vpn.com/tools/what-is-my-dns-server/ on my iPad and disconnecting/re-connecting WiFi (to force my iPad to re-evaluate its DNS for my network) after turning Advanced Security off and on shows that my Eero will only use my custom 1.0.0.1 DNS configuration when Advanced Security is off.
So I was wrong in my earlier post claiming the problem had re-occurred for me. I had inadvertently reverted back to using TalkTalk's DNS server by turning Advanced Security in my Eero app back on last night. Sorry for the false alarm! But I have at least shown that TalkTalk is still sending my traffic to a CDN that is blocking me and switching to 1.0.0.1 is still a workaround.
Message posted on 24 Sep 2025 12:25 PM
Geoff great update as ever, I have been stable using 1.1.1.1 primary and 1.0.0.1 secondary DNS on router I still IPv4 due to my area being legacy ADSL once coverage extends will change over.
AnnieUK advice has fixed me ormslly if use google DNS which probably will work also
i only tested to ensure it was still working I'm glad to resolved same as when you thought it reoccurred I was having a sqeaky bum moment to be honest in think I'll just keep my router DNS as is now with Cloudshare oh and my advanced security is turned off alsi
Message posted on 24 Sep 2025 12:50 PM
@ handi+andi has just posted on the Sky Q thread that Sky have confirmed the issue is with them and should be resolved in 48 hours.
Message posted on 24 Sep 2025 01:01 PM
@Geering1993 and anyone else who, so far, hasn't been confident enough to change anything on the Sky+ Box.
Here's what I did
Press Services and navigate to Settings then Network.
Press Down Arrow (this brings up the option to press Green for Manual IP Configuration)
Press Green
Take a photo of this screen so that you can always go back if it goes wrong.
The only entry I changed was DNS.
Press Down Arrow 3 times to get to DNS (mine said 79.79.79.79)
Press 1 Right Arrow 0 Right Arrow 0 Right Arrow 1 (to change it to 1.0.0.1)
Press Green to Save
Press Sky and try a Download.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 24 Sep 2025 01:07 PM
Thanks everyone for the advice and help today. Seen as Sky are onto the problem, I'm gonna hold fire and trust in them to sort it out lol. We will see what tomorrow brings!
Message posted on 24 Sep 2025 01:10 PM
Ojo1 - what a thoughtful post for us non-techies! It's a shame Ive already entered 1.0.0.1 to no avail, but thank you for explaining things so succinctly 😊
Message posted on 24 Sep 2025 01:15 PM
Annie - you'll be pleased to know that I have pressed the red button and things are back to the way they were - the WPS button didn't help but entering the WiFi password did. Thanks for your patience.
Message posted on 24 Sep 2025 02:11 PM
Trouble Downloading box sets
I have a sky + box. I can record a program but all of a sudden downloading from box sets has stopped working.
Message posted on 24 Sep 2025 02:25 PM
Re: Trouble Downloading box sets
Sky are aware of the problem and are hopefully working on a solution. They hope to have it sorted in the next 48 hours
Message posted on 24 Sep 2025 02:45 PM
Download issues
I have 3 old hd boxes in the house. None of them will download anything. They will record still. I cannot watch anything from the purchased list either. Internet is fine. I have tried turning off the router and my sky box and then rebooting. Sky box reconnects and I can view my purchased list and everything that's on demand but I cannot download anything. I have also tried in sd as well but it's the same
Message posted on 24 Sep 2025 02:49 PM
Re: Download issues
I have moved your post into the Sky+ thread discussing this. There's also a similar thread on the Sky Q board. Sky are aware of these issues.
Please see the post currently marked as the answer.
Message posted on 24 Sep 2025 04:58 PM
Re: SKY+ HD DOWNLOADS
If you're on TALK TALK and have an eero router go into network controls and turn advanced security off ! Downloads work instantly !! Think talk talk deem skys download address as a dangerous site
Message posted on 24 Sep 2025 05:02 PM
What is an eero router?
Message posted on 24 Sep 2025 05:11 PM
Talk talks full fibre router
Message posted on 24 Sep 2025 05:15 PM
eero is a mesh Wi-Fi system that uses multiple devices to create a single, seamless network, providing fast, reliable Wi-Fi coverage throughout your entire home and eliminating dead spots. Courtesy of Google
