2
This discussion topic has been answered Discussion topic: Sky box
This message was authored by: Lynndavidson
Sky box
Tried all suggestions regarding the poor satellite reception. Nothing working will need new sky box.
This message was authored by: Mark39 Answer
Re: Sky box
@Lynndavidson poor reception is much more likely to be caused by a problem with your dish and/or cabling than your Sky box. Unless you have a particular wish to upgrade, you may be better off getting a local satellite engineer out to take a look at your dish.
Re: Sky box
@Lynndavidson
You will not get a new Sky+ box from Sky should you call them about this as they will insist that you upgrade to a Sky Q box.
Re: Sky box
