Discussion topic: Problems receiving channels
This message was authored by: AB93
I am unable to get many channels on both my boxes
Avatar for AB93
Re: Problems receiving channels
Please advise
Please explain FULLY what is happening
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@AB93 if there's an error message, what does it say?
Avatar for AB93
Hi, I am getting some channels, but some channels are showing a message "not getting a signal)
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
