1
This discussion topic has been answered Discussion topic: Sky HD + viewing card replacement
This message was authored by: Martin4
Sky HD box replaced, old viewing card not accepted.
This message was authored by: SKY1992bf Answer
Re: Sky HD + viewing card replacement
@Martin4  You can no longer replace sky plus hd boxes as of end October 24
the cards are now permanently locked to the last box they were paired to at end of October 24
sky plus is now a legacy system which sky no longer sells or supports, whilst existing hardware will continue to work for the foreseeable future , as you have discovered any hardware that breaks down moving forward cannot be replaced unless you upgrade to one of sky's current systems sky Q glass or stream to continue viewing sky services
