7
This discussion topic has been answered Discussion topic: Sky+HD hard drive failed
This message was authored by: Maggie3248
The hard drive has failed on my Sky+hd box
Can it be replaced?
I gather the option of buying another box from eBay and transferring the viewing card has been blocked, but would putting a new drive in still work?
This message was authored by: Annie+UK Answer
Re: Sky+HD hard drive failed
AFAIK the HDD can be swapped and the card be paired but I have not seen anyone post a confirmation, it is much easier to get Sky to upgrade you to a newer system
Can it be replaced?
YES
Viewing card are locked to the box they were paired to at the end of October 2024
Avatar for Maggie3248
I understand that the viewing card is locked to the box.
But is the card locked to the HDD?
If I got someone to replace the HDD would it still work with the viewing card?
(Sorry if I seem thick!)
@Maggie3248 I'm with @Annie+UK on this. I don't think the Card is linked to the HDD. But unless you have an overriding wish to keep Sky+, it would make more sense to switch to Sky Q or Stream.
Thanks, you're probably right.
It's a too much hassle just because I'm trying to avoid changing from a setup I've been happy with. I could end up wasting time and money.
@Maggie3248 just as an afterthought. if you were thinking about replaciong the HDD as a DIY project, I understand it's not very easy! Fiddly to access etc.
@Mark39 Yup! I've seen a YouTube video and decided it was too fiddly for me.
Extra hassle and expense of paying someone else means it's probably not worth it.
