Discussion topic: Sky+ Box no longer active
Message posted on 18 Sep 2023 04:38 PM
I was with Sky for many years though after not wathing much tele decided to cancel however, the box is totally deactivated by Sky and I cannot access my main channel, Racing TV. I have tried to contact them to see if they can put it back on but it is impossible to get anywhere ! The VA is an absolute shambles and I can't speak with a human being - all very frustrating.
Has anyone else struggled with getting access to Racing TV? I have an Amazon Firestick but the action is delayed by 10 seconds or so which isn't great when using betting exchanges,
John
Message posted on 18 Sep 2023 04:47 PM
Re: Sky+ Box no longer active
Sky don't deactivate Sky+ boxes. Can you expand on what's happening? Do you get to the main Menu? Is the box connected to your satellite dish? Any error message?
Message posted on 18 Sep 2023 04:48 PM
Racing TV is a premium channel that you have to subscribe to via them yourself.
Sky Sports Racing is part of the Basic TV package.
Message posted on 16 Oct 2023 07:19 AM
I am getting the message, "Your Sky+HD Box isn't getting a satellite signal". I can access the menus etc though the message for TV Guide and Sky+ is always "your box is still initialising"
Message posted on 16 Oct 2023 07:20 AM
I have the subscription for Racing TV however non of the channels work, even the premium, paid for Racing TV
Message posted on 16 Oct 2023 07:27 AM
@nudge48 Without a satellite signal nothing will work. First check that the satellite cables are still firmly connected to the back of the box.
Assuming they are, you will need to contact a local satellite company to come out and look at the dish, LNB and external cabling to find and fix the problem.
Sky no longer send engineers to Sky+HD systems.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 16 Oct 2023 11:52 AM - last edited: 16 Oct 2023 11:57 AM
You cannot use a Sky box for an individual externally-billed add-on subscription without having the minimum Sky subscription channel bundle ('Signature') as well.
Message posted on 26 Oct 2023 04:36 PM
I have got my subscription back now however the box is sitll not receiving a signal..... think I'll have to try support 😞
Message posted on 26 Oct 2023 04:39 PM
Sky are no longer providing support for Sky+ boxes, I'm afraid, so unless you have Sky Protect, you'll need to get a local satellite installer to come out to investigate the signal issue.
@nudge48 wrote:I have got my subscription back now however the box is sitll not receiving a signal..... think I'll have to try support 😞
@nudge48 if support are unable to fix over the phone, you will need to employ the services of a third party engineer to look at your setup as Sky no longer supports engineer appointments
Message posted on 26 Oct 2023 06:19 PM
thanks Mark.
Do you know what Sky Q is? I can't seem to find much out about it
Message posted on 26 Oct 2023 06:41 PM
@nudge48 wrote:thanks Mark.
@nudge48 see
Message posted on 26 Oct 2023 06:57 PM
ah lovely, cheers mate
