Discussion topic: Since yesterday I have had the message on my sky box+ there is a problem with your hard disk drive.
Message posted on 23 Oct 2023 12:56 PM
Since yesterday I have had the message on my sky box+There is a problem with your hard disk drive. I can not get on demand and I can not record. Can someone help.
Message posted on 23 Oct 2023 01:03 PM
Re: Since yesterday I have had the message on my sky box+ there is a problem with your hard disk dri
Try a Planner Rebuild
Message posted on 23 Oct 2023 02:34 PM
It just says the planner cannot be rebuilt in diskless mode.
Message posted on 23 Oct 2023 02:55 PM
See Q14
Message posted on 25 Oct 2023 09:57 AM
Hard disk drive error
I have had the hard disk drive problem since Sunday, have tried everything possible to know avail, have come to the conclusion the sky boxhd+ has had it, I can still watch sky tv but I have lost everything in my planner, I cannot record or download anything on demand. So it looks like I will have to upgrade to sky Q or sky glass, which is going to cost me. Also with sky Q I have been told I need another aerial, which I'm not sure is allowed where I live.
Message posted on 25 Oct 2023 10:14 AM
Re: Hard disk drive error
@Chantal59 yes, it's likely that the hard disk has failed, as they all do eventually. If you don't want to upgrade, you'll find used Sky boxes available cheaply (don't pay more than around £30) on ebay etc. Just look for a DRX890 or DRX895 model.
You shouldn't normally need a new dish for Sky Q, but it will need an updated LNB (the bit on the arm).
Message posted on 25 Oct 2023 10:49 AM
Thank you for the advice, if I was to get another Sky hd+ box on eBay for example, do I need to keep the slot card from my old device, because doesn't that have all the information from my account with sky, and do I have to notify sky.
Message posted on 25 Oct 2023 10:55 AM
Yes, keep your viewing card
No.
Message posted on 26 Oct 2023 07:21 AM
@Chantal59 You'll just need to pair your viewing card to your new box. Instructions to do this can be found in Annie's FAQ's in the link on one of her posts above.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 26 Oct 2023 10:56 AM
Thank you 😊
Message posted on 30 Oct 2023 10:51 PM
Re: Replacement Sky HD+ box
@Mark39 My boyfriend has an old sky box, however it's not HD can I use this to replace my skyhd + box where the hard disk drive isn't working.
Message posted on 31 Oct 2023 09:37 AM
@Chantal59 yes, you can do that. You'll need to pairmyour Viewing Card as @oj01 posted. Do be aware, though, that as it's a non-HD box, you'll see the big red banner on BBC channels warning you of the impending closure of SD broadcasts - and that will appear on your recordings too.
Message posted on 31 Oct 2023 10:50 AM
@Mark39 Thank you for replying to my question. I appreciate it very much. 👍
Message posted on 04 Nov 2023 02:49 PM
Hi, I've had the same problem since early this morning!
The cynic in me says that this might be a way of getting all existing Sky+ users to upgrade their hardware as Sky + is no longer supported.
I have tried all the suggestions on the forum which have been a great help but to no avail and my initial thoughts are to source a second hand Sky+ box as a replacement.
I am currently mid way though an 18month contract, if I was to upgrade and replace with SkyQ, does that mean I would be tied into another 18 month contract from date of upgrade?
Message posted on 04 Nov 2023 02:56 PM
All hard disks fail eventually. Yours must be at least 8 years old. Which do you think is more likely - Sky somehow infiltrating your Sky box or old age failure?
That would resolve the problem, at least temporarily. Just choose a DRX890 or DRX895 as they're the most recent.
Yes, it would probably mean a new 18 months contract, but you might want to check directly with Sky.
