Discussion topic: Second sky + hd drx890
This message was authored by: Bugsy1550
Hi, I wanted to know if I purchased a sky + hd box, for my caravan, could I get a second biewing card please
Re: Second sky + hd drx890
@Bugsy1550
That's not allowed as per the T's and C's you agreed to.
@Bugsy1550  No, sky no longer sells or supports sky plus hardware and subscriptions
existing hardware and subscriptions will continue to work for the foreseeable future but you can't add to them
also as noted by @Daniel0210 it's also against terms and conditions which only permits use at the registered address on your account
Below is from Sky's Terms & Conditions
4.4. You must only use the Viewing Card for private viewing purposes. You must not use it for any commercial or business purpose or in any premises other than your address.
4.5. The Viewing Card must not be used outside the country (either the UK or Republic of Ireland) it was supplied for use in.
