Discussion topic: No Sky Channels
This message was authored by: Linda541
No Sky Channels
I have been paying my brothers Sky subscription for over 20 years. They do not have any internet connection. Over the last couple of months they have not been able to watch any channels. This happens for 2 or more days and then the channels come back on again.  I am paying over £90 per month and feel I am wasting my money if they cannot watch their programmes. They do not want a Q box as Teletext Service is a must for them as is Live Sport Channels. The viewing card is inserted properly so can anyone tell me why this keeps happening.  Thank you.
Re: No Sky Channels
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
Re: No Sky Channels
@Linda541sky plus is a legacy product that Sky no longer sells or supports
  If they are getting no satellite signal message then unless he has sky protect insurance you will need to employ the service of local contractor to check the dish for realignment issues
if it's not the dish at fault the only option is to source a second hand sky+hd box from well known auction sites
