Discussion topic: Sky+ box keeps losing signal & requires restarting almost daily
Message posted on 01 Aug 2024 12:32 PM
My Sly+ box is losing certain chanels & requires the box to be restarted, driving us mad! It is now not recording programmes that are set on the series link, go to watch on planner and it says failed.
Message posted on 01 Aug 2024 12:34 PM
Re: Sky+ box keeps losing signal & requires restarting almost daily
The synopsis of a failed recording should give a reason
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
