12
This discussion topic has been answered Discussion topic: EPG problem for +24 hrs using the Yellow button
This message was authored by: alchal
Hi, I have a Sky+ HD DRX 895 2GB box, bought today. Setup seems fine and signal strength and quality are good, and HD channels are working fine. But on the EPG when I use the Yellow button for +24 hours I just keep getting "no listings available" message for every channel. A previous solution suggested on here recommended switching the input cables over, but I'm using one cable / single feed mode on input 1.
I would be eternally grateful for any solution to this problem.
This message was authored by: Annie+UK Answer
Re: EPG problem for +24 hrs using the Yellow button
It could be the tuner is in use so much that the future guide data is taking a bit longer to load, I would wait a couple of hours and try the yellow button again, if it still does not work then perform a factory reset (instructions are in my Sky Plus FAQ)
You need to set Single Feed Mode on in the Installer Menu. If you need help to find it, let us know,.
Avatar for alchal
Level 2 icon
Thanks Mark, but I've already done that.
Rebooted since changing it? Turn off at the plug for at least 4 minutes.
Have you performed a New Install from the hidden menu?
Avatar for alchal
Level 2 icon
Hi Annie, yes I have.
Mark, no but I'm doing so now.
Avatar for alchal
Level 2 icon
Mark, I rebooted it but it's still the same. It's just showing 24hrs worth of listings on all channels.
Avatar for alchal
Level 2 icon
Thanks Annie, I'll try that.
I've also just noticed that when I'm on the EPG it's also saying that "Programme synopsis is not available"
That's another symptom of Single Feed Mode not set (or not working!). I might be stating the obvious, but just checking - did you remember to save the setting after you changed it?
Avatar for alchal
Level 2 icon
Thanks Mark
I've just checked and Single Feed Mode is marked as 'On'
Avatar for alchal
Level 2 icon
Spot-on Annie, it was just a matter of waiting a couple of hours for it to populate.
Many thanks to both of you.
Glad you're sorted 🙂
