Discussion topic: Clock running late..Why
This message was authored by: tosher
Why is my sky HD + Box running late. Does anyone know why???
Re: Clock running late..Why
Are all the times wrong in your TV Guide, so is the BBC News at 10 showing as starting at 9pm for example ?
@tosher  it's a cosmetic fault on the time stamp on recording that has been a round a few years and only occurs during bst
when the clocks get back the time stamp will be correct again until the clocks go forward again and so on
Sky has confirmed that has it's only cosmetic and doesn't impact the boxes ability to function correctly there are no plans for a fix given it's a legacy product
or is it as @caesarome describes as it could be one of two bugs one can be fixed the other can't
Avatar for tosher
Tv guide says bbc news at 9pm but has just started at 10pm, like all programs!!
 @tosher  What software is your box running
press services > settings > system details
Can you post what the model number is
What is the software version of your Sky Box?
See Q08 in my Sky Plus FAQ
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for tosher
according to information it is the latest version. I have only had this box for a few weeks as the old one went wrong and the new one was replaced by a sky engineer ...
The chances are it isn't running the latest software as Sky released a patch to fix this very issue last year so when you are not using it or recording/downloading it then try updating the software.
https://www.sky.com/help/articles/updating-sky-box-software-sky-plus-hd
Avatar for tosher
Hi, the model No is R024.092.08.00P
Latest is: R024 . 092 . 11 . 00P
See Q04 for update instructions
Avatar for tosher
What do you suggest?
Just perform a software update (see Q04 in my Sky Plus FAQ)
Avatar for tosher
R0.24.092.08.00P
@tosher wrote:
R024.092.08.00P
Yes that is OLD and needs updating to fix the time bug you are experiencing
Avatar for tosher
Hi, it's me again, I phoned Sky this morning and the person I spoke to asked me what the problem was.I explained and said that I had tried everything I could but with no success to sort the problem and she said that the box that I have is no longer used and that I should upgrade to Sky Q. Anyway she said that as the box was only installed 2 weeks ago by a Sky engineer she would try to upgrade the software and reset the whole box, and with her instructions I managed it and Bingo it now works fine....Please don't ask me what the instructions were because I am in my eighties and wouldn't be able to remember them.
       The best advice would be that if you have the same problem get in touch with Sky and ask them to talk you through to solve the problem....Thanks for the Community to try and help me..
