Discussion topic: Can’t reset sky+ plus remote
Re: Can’t reset sky+ plus remote
You are not programming the remote properly 😞
  • Press TV on your Sky Remote
  • Hold down select and the red button at the same time until the red light at the top of your Sky remote flashes twice,
  • type 9 9 9 and press Select.
These instruction are given by the link Mark provided and should also be on a sticker on the battery door
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
@Mark39 wrote:
@Cae+Lloi wrote:
Tried 999 nothing happened just says channel not available
999 just resets the remote. I wouldn't expect anything to happen, apart from the LED in the remote flashing twice to confirm success. It just means that any TV code you had previously programmed will be deleted.
Next step would be to re-programme your remote with the correct code for your TV.
I think they just typed 999 without following the full programming instructions thus the message "channel not available" 😞
Avatar for Cae+Lloi
This message was authored by: Cae+Lloi
I've tried all that has been suggested but still nothing is working what am I doing wrong?
See question Q43 in my Sky Plus F⋅A⋅Q
Let's go back to basics. What are you trying to do? If you're trying to reset your remote, why? What problem are you having that makes a reset necessary?
Avatar for Cae+Lloi
All of the buttons work apart from the volume and mute
Does the LED in the remote flash when you press the volume up/down and mute buttons?
Avatar for Cae+Lloi
Yes I think so
It's worth checking to be sure. If the buttons are faulty  the only thing that might help is to take the remote apart and clean the internals. @Annie+UK's FAQ explains how.
Avatar for Cae+Lloi
Ok I'll try that next thanks. Do you think it's worth getting a new one?
If your remote has worked OK before with your present tv, it might be. They're not very expensive.
Avatar for Cae+Lloi
Ok thanks for your help
