Discussion topic: Can’t reset sky+ plus remote
This message was authored by: Cae+Lloi
The volume and mute buttons don't work on the remote. I have tried unplugging the sky box & pressing 6 & 9 etc on the controller but the led light doesn't flash twice
Re: Can’t reset sky+ plus remote
This is the Sky Plus forum!! It looks like you don't have a Sky Plus remote 😞
I am NeurodivergentMy Sky FAQs : Go Stream Glass Plus
Bit confused. If it's a Sky+ remote you need to programme it with the code for your TV. This explains how: https://www.sky.com/help/program-your-remote
How far do you get?
Avatar for Cae+Lloi
I have tried theses steps a few times but nothing works. When I try to reset the control the red button doesn't flash twice. I have tried to unplug the sky box also
Avatar for Cae+Lloi
It is a sky+ remote as that is the sky box I have!
To reset a sky plus remote you can program it with code 999 or take the batteries out and press select for 30 seconds
I did not understand what holding 6 & 9 was supposed to do as the above is the reset instructions 😞
@Cae+Lloi as @Annie+UK pressing 6 & 9 doesn't reset the remote. The remote will just see it as a new, incomplete code, which is why the LED doesn't flash.
@Mark39 The newer system have procedures that require two number keys be held down at the same time, this is why I thought the OP did not have a Sky Plus remote
Avatar for Cae+Lloi
Ok so what do I need to do now?please
You're right it does, but not 6 + 9.
7+9 resets a Sky Q remote.
Have you reset your remote using one of the procedures I outlined above? You can then try programming it for your TV after the reset
Avatar for Cae+Lloi
Ok so is there anything I can do now please
Avatar for Cae+Lloi
Tried 999 nothing happened just says channel not available
999 just resets the remote. I wouldn't expect anything to happen, apart from the LED in the remote flashing twice to confirm success. It just means that any TV code you had previously programmed will be deleted.
Next step would be to re-programme your remote with the correct code for your TV.
