This discussion topic is read only Discussion topic: Audio Description won’t turn off
This message was authored by: Jilly24
My Sky Audio Description will not turn off.  I have never put it on and the settings show that it is off. I have tried turning in on and off again but no joy it's still describing things. Please help us as it's driving us insane
Locked
This message was authored by: SDR
Re: Audio Description won’t turn off
Have you tried rebooting your box?
Stuart R
I am responsible for the content, but not the way it is presented, I have some sight issues
Auto-Correct is my enemy.
Sky Glass - No Puck
Also note that anything Recorded with it on, will always have it on even though you've now turned it off.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
This message was authored by: Flamber
If you have turned it off and it is still appearing in your recordings then this would be because they were recorded at a time when it was turned on, but it should happen from now on.
This message was authored by: Danw867465
I have exactly the same problem. Recorded a tv show on bbc, went to watch it and turned on audio description by mistake, turned it off but it's still giving an audio description.
Audio description was not on when it recorded.
See question Q20 in my FAQ
This message was authored by: gplanner
This happened to us.  Found out that it is turned on by holding the mute button for 3 secs (that was the inadvertent mistake), but it turned off by holding down the mute button again for 3 secs.
Locked
