This discussion topic is read only Discussion topic: LG Magic Remote won't recognise Sky+HD channels using voice recognition.
This message was authored by: Hallsfell
On my LG C9 Oled, I had used LG magic remote voice recognition perfectly when connected to Sky HD.  However, had changed to Sky Q recently, but then changed back to Sky HD again after 2 weeks.  Have tried to reset remote on Sky HD box again and it does say Complete on the TV, but it clearly isn't.  On the TV it now only gives the Sky options of Sky Q, Sky SD and Sky but, when it was working before there was the option of Sky HD on the TV list, but this has disappeared.  The voice remote can still be used to come out of apps and back into the Sky HD box, so it looks like it's not recognising the functions of the Sky HD box only, that is, it doesn't change channels that way.  Any advice please?
Locked
Re: LG Magic Remote won't recognise Sky+HD channels using voice recognition.
If the magic remote has a factory reset option, it might be worth a go. Otherwise probably better to try LG support or the LG forum, if they have one.
Check that your LG is detecting your Sky box correctly via HDMI as it uses this to link your magic remote to the device, you should not eed to reset the remote as it configures itself automagically 🙂
I am NeurodivergentMy Sky FAQs : Go Stream Glass Plus
Avatar for Hallsfell
Many thanks - the HDMI link is showing as ticked on the TV, so I presume this is working.  I'm still wondering that, because it doesn't now show Sky HD as an option on the TV, that may be the problem.
Locked
