13
This discussion topic has been answered Discussion topic: sky stream
This message was authored by: bobby+shop
sky stream
I can only get standard HD channels on the puck, all other channels such as plus 1, sky one, cinema,sport  etc have all dissapeared
This message was authored by: MarkGoldsmith Answer
Re: sky stream
@bobby+shop you can try a reboot of the puck ( just turn it off at the plug for a couple of minutes and see if that helps).
If it doesn't work perhaps you can attach a photo of what you are seeing on your screen so that we can be of assistance.
This message was authored by: Jones_The_Cat
Re: sky stream
This is correct. Sky Stream does not have the +1 channels. The full channel list is available here:
https://www.sky.com/help/articles/tv-channel-list-sky-glass
Avatar for bobby+shop
Re: sky stream
My stream channels have disappeared only have bbc/itv  etc in HD that's it, used to have sport, sky one etc etc
Re: sky stream
Have they worked before on your Stream puck? Did you switch from Sky Q to Sky Stream?
What happens when you navigate to the TV guide?
Re: sky stream
Re: sky stream
Unbelievably it worked- rebooted everything and hey presto I all channels  back- weird but good, thank you
Michael
Re: sky stream
@bobby+shop did Sky One return?
This message was authored by: PSC133
Re: sky stream
Michael
The more that you use your puck you will find that a reboot can solve many different issues!
Re: sky stream
The Sky Stream system will hopefully become more stable with time on Sky Glass TVs and Sky Pucks🤔
Re: sky stream
Hi, no sky one has not returned with the others , can you advise how I get that back as well?
regards Michael
Re: sky stream
regards Michael
Sky One does not exist any more. Sky Max replaced it years ago.
Re: sky stream
@Jones_The_Cat wrote:
regards Michael
Indeed, if you want Sky One back in the UK you will need to get a Time Machine and go back a couple of years to before it was closed down.
This message was authored by: Jonathanphillip
Re: sky stream
Sky one as a new name now its  changed can't think  of it
Re: sky stream
Sky Showcase directly replaced in on the EPG, Sky Max was really the replacement channel in where the shows ended up and it being more general entertainment Sky branded channel
