Discussion topic: 99% of the time I turn on my sky puck I have to reset it to make it work. Works fine after a reset-
This message was authored by: Adrian67
Message posted on 28 Mar 2024 05:38 PM
My puck only works after a reset (power off then on again)
is this a puck problem?
Find out more
Message posted on 28 Mar 2024 06:27 PM
Re: 99% of the time I turn on my sky puck I have to reset it to make it work. Works fine after a res
Hi @Adrian67
So.when you press the button on the remote, it's not responding? What happens if you press the button underneath the puck?
It might be worth un-pairing and re-pairing your remote if it's working using the button underneath. See: https://www.sky.com/help/articles/remote-control-help-sky-glass
The other thing to try is turn Networked Standby Mode ON and overnight power saving OFF in the startup and standby section of the settings.
MikeAlanR
