This discussion topic has been answered Discussion topic: sky stream
Message posted on 11 Jan 2024 02:18 PM
I can only get standard HD channels on the puck, all other channels such as plus 1, sky one, cinema,sport etc have all dissapeared
Message posted on 11 Jan 2024 06:09 PM
@bobby+shop you can try a reboot of the puck ( just turn it off at the plug for a couple of minutes and see if that helps).
If it doesn't work perhaps you can attach a photo of what you are seeing on your screen so that we can be of assistance.
Message posted on 11 Jan 2024 02:20 PM
Re: sky stream
@bobby+shop wrote:I can only get standard HD channels on the puck, all other channels such as plus 1, sky one, cinema,sport etc have all dissapeared
This is correct. Sky Stream does not have the +1 channels. The full channel list is available here:
Message posted on 11 Jan 2024 03:34 PM
Re: sky stream
My stream channels have disappeared only have bbc/itv etc in HD that's it, used to have sport, sky one etc etc
Message posted on 11 Jan 2024 05:43 PM
Re: sky stream
@bobby+shop wrote:My stream channels have disappeared only have bbc/itv etc in HD that's it, used to have sport, sky one etc etc
Have they worked before on your Stream puck? Did you switch from Sky Q to Sky Stream?
What happens when you navigate to the TV guide?
Message posted on 13 Jan 2024 09:28 AM
Re: sky stream
Unbelievably it worked- rebooted everything and hey presto I all channels back- weird but good, thank you
Michael
Message posted on 13 Jan 2024 11:22 AM
Re: sky stream
@bobby+shop did Sky One return?
Message posted on 13 Jan 2024 11:27 AM
Re: sky stream
@bobby+shop wrote:Unbelievably it worked- rebooted everything and hey presto I all channels back- weird but good, thank you
Michael
The more that you use your puck you will find that a reboot can solve many different issues!
Message posted on 13 Jan 2024 11:37 AM
Re: sky stream
The Sky Stream system will hopefully become more stable with time on Sky Glass TVs and Sky Pucks🤔
Message posted on 17 Jan 2024 11:09 PM
Re: sky stream
Hi, no sky one has not returned with the others , can you advise how I get that back as well?
regards Michael
Message posted on 17 Jan 2024 11:10 PM
Re: sky stream
@bobby+shop wrote:Hi, no sky one has not returned with the others , can you advise how I get that back as well?
regards Michael
Sky One does not exist any more. Sky Max replaced it years ago.
Message posted on 17 Jan 2024 11:18 PM
Re: sky stream
regards Michael
Indeed, if you want Sky One back in the UK you will need to get a Time Machine and go back a couple of years to before it was closed down.
Message posted on 28 Mar 2024 05:24 PM
Re: sky stream
Sky one as a new name now its changed can't think of it
Message posted on 28 Mar 2024 05:30 PM
Re: sky stream
@Jonathanphillip wrote:Sky one as a new name now its changed can't think of it
Sky Showcase directly replaced in on the EPG, Sky Max was really the replacement channel in where the shows ended up and it being more general entertainment Sky branded channel
