Discussion topic: You tube problem
Message posted on 25 Jul 2026 11:07 AM
You tube problem
Keep getting black screen on tv screen for you tube. Having to switch off and on Sky stream box to connect again? Is this WiFi problem?
Message posted on 25 Jul 2026 01:00 PM
Re: You tube problem
I was having exactly the same problem every time that I started the you tube app, had to reboot the sky stream to resolve the problem.
I have installed a time switch to switch off the puck overnight and switch on again the next morning, that has solved the problem for me....works eveytime now!
Message posted on 25 Jul 2026 06:19 PM
@Cloncurry @SBL22 Have either of you tried the App refresh in Settings?
Message posted on 25 Jul 2026 06:54 PM - last edited: 25 Jul 2026 07:00 PM
When I get odd stuff happening with the interface and apps, I go into Settings->System Management->Resets & Updates and run Restart Device. Takes a couple of minutes and all is well after that for me until the next time. From experience it's probably due to developers not clearing caches and buffers correctly if at all.
I forgot to mention that all settings and log ins are preserved.
Sky Stream, Sky Glass, Philips 77OLED+950, Pioneer LX-901 7.1.4, EE 900 FTTP
Message posted on 25 Jul 2026 07:00 PM
Thank you all for your help, will try these suggestions
