Discussion topic: Sky Stream Puck
This message was authored by: Rusty69
Sky Stream Puck
Anyone else had problem with their pucks? Only had it 3 months and it needs to be replaced. Also have been told it should only be used continuously for 6 hours.
Re: Sky Stream Puck
@Rusty69 you might be just unlucky. My Puck is almost 5 years old and is fine.Not heard about the 6 hours limit before. Did Sky (I assume) tell you why?
This message was authored by: Stephen+Mourton
Re: Sky Stream Puck
@Rusty69   Who told you it should be replaced?   Also likewise who told you it shouldn't have been used continuously for more that 6 hours?
Avatar for Rusty69
Re: Sky Stream Puck
The suggestion about the six hours came from the sky technical person.
Re: Sky Stream Puck
In that case, they weren't very technical.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
