4
This discussion topic has been answered Discussion topic: What do I do with old remote?
This message was authored by: JEFF1102
My remote started doing odd things like the volume button bringing up search instead. So phoned Sky and tried to resolve but did not work. So they have sent a replacement remote and now all good.
My question is what do i do with the old remote? Does this have to be returned to Sky like youn would if you cancelled or do you just recycle it?
This message was authored by: BenJoBanjo Answer
Re: What do I do with old remote?
You can take it to your local small electricals recycling or you can send it back to Sky for recycling. You can print off a free returns label here:
https://www.sky.com/help/articles/recycle-sky-equipment
This message was authored by: Jon34
It's because of the batteries that they supplied has leaked over the pcb inside.
if you take it apart and clean the board it will work fine and you can keep it as a spare
Not all batteries leak. Some remotes Sky supply are just faulty.
Was just saying as mine was doing exactly what you said, you wouldn't have known unless you had opened the remote as there were no signs in the battery compartment or on the batteries
