Discussion topic: Two problems with Sky Stream. Puck won’t connect to remote and can’t access Sky Store
This message was authored by GillP2 This message was authored by: GillP2
Hello,
so one of the pucks just won't connect to a remote (now tried two including a replacement from Sky as we thought the remote was the problem). What to do? Send it back? we have tried all the reset stuff in the FAQs. Tried calling Sky but nobody appears to work there on Sunday.
Second issue is everytime we try to sign into Sky Store it just says "There is an issue with the login. Please check your details and try again" but I can't enter any details. Click on retry button but it goes nowhere.
any advice much appreciated
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
Re: Two problems with Sky Stream. Puck won’t connect to remote and can’t access Sky Store
Can you log on to SkyStore.com on a PC/laptop or mobile device?
Exiled in HH
This message was authored by DAVIDB666 This message was authored by: DAVIDB666
Same issue for me - can login fine on laptop/mobile
Found a fix
  • Go to Playlist
  • Go to the bottom and select Sky Store Purchases
  • Log into your Sky account from here and you should see your content
  • Go back to the Sky Store App and you should be able to see your library
