Discussion topic: Tv guide is missing
This message was authored by: skystreampain
Re: Tv guide is missing
For me it's not even appearing under TV shows
This message was authored by: Kirstwaar
I have sky stream and the TV guide is no longer available or visible on the homepage?
The to guide has disappeared. Please help. I've rebooted and factory reset but still nothing.
Re: I have sky stream and the TV guide is no longer available or visible on the homepage?
*TV guide
This message was authored by: Chris4Stream1
Hi Dazzar51,
Thanks for your reply, but I've just taken a video, and there is NO live video section. Will post soon
This message was authored by: Shelley661
They have moved it to TV Shows, go there and scroll down
Re: Tv guide missing on Pucks
It's in TV shows, go there and scroll down, hopefully they will put it back
Not for me
This message was authored by: Scott233
Re: TV guide not on sky stream
This has happened to my sky stream also
Re: why have ALL the tv list of normal tv channels disappeared off my Sky TV puck?
@xenon81 wrote:
@Dazzar51 wrote:
They have in their lack of smart wisdom moved it to TV shows and then you have to drop down about 3 pages and it's there.
Not permanently though, it's just a bug. The TV Guide will be back in its usual place before long.
I have to agree as the TV Guide Sky Go app (Glass/Stream) hasn't been moved.
This message was authored by: Tiffani
Sky Puk not showing tv guide can’t watch any live tv programmes
Sky Pul not showing tv guide on the Home Screen. Rebooted twice and rebooted router nothing changed. I can watch apps but nothing on live tv. Has this happened to anyone what can we do??
Guys, STOP, it's NOT there
This message was authored by: Loue
Tv Guide
SKY why on earth have you moved the tv guide on sky stream - it should be on the main not several clicks away - absolutely ludicrous idea 🤬
This message was authored by: JVB2102
I have the same problem, also now it seems to be aligned to BBC london and I am in the midlands which is a bit frustrating
TV guide dissappeared
Hi, the TV guide has dissappeared from my sky stream
also have done the reboot thing and it didn't fix the problem
