7
This discussion topic has been answered Discussion topic: Technical fault
This message was authored by: Barb10
Technical fault
My screen has had a message for hours saying "there's a technical fault, please try again later". Even turning the tv off and coming back later hasn't changed a thing. Can't even watch a film as the black line with the message covers the whole top of the screen.
This message was authored by: mikealanr Answer
Re: Technical fault
Hi @Barb10
Try unplugging your Sky Stream box at the mains for a few minutes and try again. If you still having difficulty, ensure that your broadband speeds meet the requirements for Sky Stream (25Mbps for HD and 30Mbps for UHD). You may have a more stable experience plugging your box in via ethernet cable and turning WiFi off in the settings.
MikeAlanR
Re: Technical fault
Hi @Barb10
MikeAlanR
Avatar for Barb10
Re: Technical fault
Unplugging it for a few minutes worked. Thank you very much for your help.
This message was authored by: DaveDub
Re: Technical fault
@mikealanr
I've been having the same issue for the last few days with all 4 of my sky stream pucks.ive unplugged them and restarted but the problem persists.
technical fault & loss of connection are the two warnings  on screen
nothing wrong with my broadband
I run regular speed tests on my Apple devices and it's fine
seems to be a software issue with  the pucks.
im thinking it might have something to do with the latest update QOS35....
when the puck is working it streams hrd content easily so not a broadband speed problem
Re: Technical fault
@DaveDub wrote:
@mikealanr
The difference with Sky Stream is that it is a server-based system - therefore you need both a fast and stable broadband connection.
Have you run a speed check on the puck itself? To do this, open the Netflix app, navigate to the get help menu on the left and run a network check. This will tell you the actual speed the puck is receiving, not what any of your Apple devices are receiving.
Run the test a few times and see if the speed fluctuates.
Re: Technical fault
@BenJoBanjo
No I haven't tried that test.i will do later thanks.
ive had these pucks a year and a half and never had these issues.very frustrating
Re: Technical fault
@BenJoBanjo
I found the speed test in the Netflix app on sky stream.thanks for the advice
connectivity problem seems to be a compatibility issue with sky stream and my Eir broadband.no problem with any other devices in the house.
i ran the stream puck off my mobile data to test it and it works fine.
strange because I have sky stream 1 and a half years now and only coming across this problem now
This message was authored by: DiggyDuffy
Re: Technical fault
Hi.
Did the Netflix speed test. Average over five test is 85Mbps. Switched off and plugged out streamer for more than 30seconds, more than once. Technical fault persists.
This is not the only issue that has been happening recently.
Programmes stopping for no reason.
Adds (for sky Sports or other Sky products) interupting Netflix if accessed through the Sky prompt. I have a separate Netflix account.
If I go through the app this doesn't happen.
All very very disappointing.
Phone call to Sky on the morning I think. 😞
