6
Discussion topic: Technical fault on channel 134 drama
This message was authored by Jonathanphillip This message was authored by: Jonathanphillip
Just watching drama channel on 134 message popped up  there is a technical issue with this channel come back later
This message was authored by Padam_Padam This message was authored by: Padam_Padam Answer
Re: Technical fault on channel 134 drama
@Jonathanphillip
Have you tried rebooting both your router and your Stream puck?
Jonathanphillip
Any one else add this few mins ago
Jonathanphillip
I've just ran a test on my broadband it seems its down to a WiFi issue thats causing the channel to go off air WiFi with a warning ⚠️ sign might be an issue somewhere
@Jonathanphillip
Jonathanphillip
It's back now
Jonathanphillip
I was going to ring sky if it doesn't clear itself but its back now
Jonathanphillip
I tried testing broadband it seemed to take a while to find the cause and it kept circling around and said next to the hub is connected we can't find any results at the moment so I ran it again kept saying we can't find any results but after I tried it again it said WiFi issue with a warning sign next to it but I was still connected to the Internet connection no warning sign popped up saying your not connected everything Seemed fine but I tried the settings on tv to see if I was disconnected it said connected but the tv settings were all unavailable it seems when I checked on settings to see if I was connected to the Internet via tv its all back now
