This discussion topic has been answered Discussion topic: Technical fault on channel 134 drama
Message posted on 13 Jun 2024 05:29 PM
Just watching drama channel on 134 message popped up there is a technical issue with this channel come back later
Message posted on 13 Jun 2024 06:08 PM
Have you tried rebooting both your router and your Stream puck?
Re: Technical fault on channel 134 drama
Any one else add this few mins ago
Message posted on 13 Jun 2024 05:49 PM
I've just ran a test on my broadband it seems its down to a WiFi issue thats causing the channel to go off air WiFi with a warning ⚠️ sign might be an issue somewhere
Message posted on 13 Jun 2024 06:12 PM
It's back now
Message posted on 13 Jun 2024 06:13 PM
I was going to ring sky if it doesn't clear itself but its back now
Message posted on 13 Jun 2024 07:42 PM
I tried testing broadband it seemed to take a while to find the cause and it kept circling around and said next to the hub is connected we can't find any results at the moment so I ran it again kept saying we can't find any results but after I tried it again it said WiFi issue with a warning sign next to it but I was still connected to the Internet connection no warning sign popped up saying your not connected everything Seemed fine but I tried the settings on tv to see if I was disconnected it said connected but the tv settings were all unavailable it seems when I checked on settings to see if I was connected to the Internet via tv its all back now
