Discussion topic: TP Deco and Sky Stream issues
This message was authored by: GrahamBates87
I’ve recently set up a TP-Link Deco mesh system for our Wi-Fi, and after a couple of days I noticed that our Sky Stream box has been intermittently losing its wireless internet connection.  I should also note that I have replaced the router with the Deco rather than using the Deco as a booster.
I’d prefer not to use an Ethernet cable between the Deco and the Sky stream as that wouldn’t be convenient, so I’m hoping to avoid that if possible.
I keep getting there wasa techincal fault or it just saying it's not connected!
Please help!
This message was authored by: purpleparrotuk
Re: TP Deco and Sky Stream issues
I had the same I found out off someone that you need to create an IOT network on your mesh. It's  in the Deco settings. Connect your Sky puck to this. I set mine so it always connects using 5ghz. It was fine after that.
