Discussion topic: TP Deco and Sky Stream issues
This message was authored by: GrahamBates87
I’ve recently set up a TP-Link Deco mesh system for our Wi-Fi, and after a couple of days I noticed that our Sky Stream box has been intermittently losing its wireless internet connection.  I should also note that I have replaced the router with the Deco rather than using the Deco as a booster.
I’d prefer not to use an Ethernet cable between the Deco and the Sky stream as that wouldn’t be convenient, so I’m hoping to avoid that if possible.
I keep getting there wasa techincal fault or it just saying it's not connected!
Please help!
This message was authored by: purpleparrotuk
Re: TP Deco and Sky Stream issues
I had the same I found out off someone that you need to create an IOT network on your mesh. It's  in the Deco settings. Connect your Sky puck to this. I set mine so it always connects using 5ghz. It was fine after that.
Avatar for GrahamBates87
Thank you - would you try to use the Enternet cable if possible as a better fix or not?
This message was authored by: WelshGeezer
Deco user here!
I connected all my Glass TVs via Ethernet and the issue still occasionally occurred. However, it was much rarer. Since assigning each TV a static IP address the problem has disappeared.
Before switching to Ethernet, I’d recommend trying the IoT Network. I’ve never used this approach before.
Sky Glass 55" - Gen 2, Sky Glass 43" - Gen 2, Sky Glass 43" - Air (all on ethernet) & three Stream Pucks (all unused gathering dust in a drawer) powered by Vodafone Full Fibre - 910
Router? Two TP-Link Deco BE65’s (v2 / Firmware Version: 1.3.2)
Thank you!
do you have step by step instructions on how to set a static ip address up?
Launch the Deco app, click More > Advanced > Address Reservation. Click on the plus in top right and choose the Select from Client option. Then locate your Glass or Stream device and select it.
Oh yes I missed the static IP address step when I told you about the IOT network setup. Best to do
this as well (over WiFi)
