8
This discussion topic has been answered Discussion topic: T
This message was authored by: SJ82
T
The connection on my tv is not working, I've checked the stream box and the light is on, I've checked the hub box and all the lights are green, I've checked the connection on my phone and that says WiFi connected.
This message was authored by: GD1 Answer
Re: T
@SJ82  No signal is the TV telling you the input you have selected isn't the Stream Box, you need to scroll through the inputs on your TV to get the correct one.
It is nothing to do with your wifi.
Re: T
@SJ82  What message are you seeing on your TV screen?
Avatar for SJ82
Level 0 icon
Re: T
There's no message it just says no signal, I've been on to my tv settings and tried to connect to my WiFi it says connection failed however the signal is all green!
Re: T
This message was authored by: peter-marlow+1966
Re: T
Have checked  the hdmi  connection to the tv
P c marlow
Avatar for SJ82
Level 0 icon
Re: T
Of course!!!! Silly me the one thing I didn't check thank you feel like a plum now!! lol
Re: T
Make sure that it is pushed  in at both ends
P c marlow
Avatar for SJ82
Level 0 icon
Re: T
Thank you!! can't believe I didn't think of that
Re: T
I hope everything  is  working OK now
P c marlow
