4
This discussion topic has been answered Discussion topic: Stream not working
This message was authored by: Sharon97
Stream not working
Hi the movies etc won't download and play and channels are missing, only 4 music channels showing etc. also can't find radio channels at all
This message was authored by: MarkGoldsmith Answer
Re: Stream not working
Everything is streamed, nothing downloads. How are you trying to access the film you are having problems with?
Thats correct, only the MTV music channels are currently avaiable on the Sky streaming platform since Channel 4 closed The Box music channels last week. There are plenty of music related streaming apps instead including Amazon Music, Spotify and Vevo on the platform. Vevo itself has several live streaming music channels.
Radio stations aren't on the streaming EPG. You need to use the radio apps to access the radio stations e,g (Global Player, Radio Player or BBC Sounds).
Music can be accessed via the music apps ... and radio via the radio apps😉
Avatar for Sharon97
Hi thanks for reply.
didn't know about the music channels are they all still available on q? I've recently changed over and they was loads on there.
When I try and play a movie it just goes to a black screen nothing is happening. They was playing fine when first went onto stream. Thanks
This message was authored by: Jporch316
The ones mentioned have closed permanently from all platforms.
Answered - Go to Answer
