Discussion topic: Stream box
Message posted on 23 Jun 2025 02:35 PM
Stream box
How can I download Netflix to my streaming box
Message posted on 23 Jun 2025 02:40 PM
Re: Stream box
@Paulellis1 You don't download any apps to a stream puck, they will already be there, including netflix.
Message posted on 23 Jun 2025 02:59 PM
Re: Stream box
@Paulellis1 Have a look at the Home Screen and it will be there a short way down along with all the other apps.
Message posted on 23 Jun 2025 03:03 PM
Re: Stream box
Hi I've looked it's not there
Message posted on 23 Jun 2025 03:37 PM
Re: Stream box
@Paulellis1 wrote:Hi I've looked it's not there
Try rebooting the puck fully and also do an app refresh from the settings menu. The apps are all stored on Sky's servers, not on the puck itself, so it can sometimes take a little while for your link to the server to fully establish.
Message posted on 23 Jun 2025 03:38 PM - last edited: 23 Jun 2025 03:46 PM
Re: Stream box
Are you seeing other apps on the Apps & Inputs rail, that is down from the Home rail?
It should show many other apps, like iPlayer, ITVx, Disney+, Paramount+, YouTube, Xumo, Discovery+ etc.
If you click on the first tile that says Apps & Inouts,, the apps are put into rail categories, like Featured, Sky's picks, Music, Entertainment, Sports etc.
You will find Netflix in the Entertainment rail.
You can also say 'Netflix' with your Sky Stream voice remote to start it up.
If your are still not seeing it or able to voice open it, try a restart in the Sky Stream puck settings;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
