6
This discussion topic has been answered Discussion topic: Sound echoing on channel 5 program's
This message was authored by: Bazza439
We're having continuing problems with the sound on channel 5 program's.
We watch the LG TV using a LG soundbar. However even when using the TV alone, we still have the same problem.
Can anyone help please?
This message was authored by: Ndg48 Answer
Re: Sound echoing on channel 5 program's
We're having the same issues with the same set up.
I've changed my sound setting to Dolby Digital Plus through the Sky remote.  It's working with no effect on the other channels- so far!
Did you solve yours?
@Bazza439  Is this happening with a Sky stream puck?
Avatar for Bazza439
Yes this is happening using a Puck
@Bazza439  Have you tried differen sound options in the stream pucks setting menu?
Avatar for Bazza439
Will that not effect the other channels?
Avatar for Bazza439
Thanks, as it turns out, I did the same thing last night and upto now everythings working fine.
I appreciate you getting back to me to help.
Cheers
