This discussion topic has been answered Discussion topic: Sound echoing on channel 5 program's
Message posted on 15 Apr 2024 04:49 PM
We're having continuing problems with the sound on channel 5 program's.
We watch the LG TV using a LG soundbar. However even when using the TV alone, we still have the same problem.
Can anyone help please?
Message posted on 16 Apr 2024 10:36 AM
We're having the same issues with the same set up.
I've changed my sound setting to Dolby Digital Plus through the Sky remote. It's working with no effect on the other channels- so far!
Did you solve yours?
Message posted on 15 Apr 2024 04:51 PM
							Re: Sound echoing on channel 5 program's
@Bazza439 Is this happening with a Sky stream puck?
Message posted on 15 Apr 2024 04:53 PM
Yes this is happening using a Puck
Message posted on 15 Apr 2024 04:54 PM
@Bazza439 Have you tried differen sound options in the stream pucks setting menu?
Message posted on 15 Apr 2024 06:33 PM
Will that not effect the other channels?
Message posted on 16 Apr 2024 04:31 PM
Thanks, as it turns out, I did the same thing last night and upto now everythings working fine.
I appreciate you getting back to me to help.
Cheers
